12's with this setup????
Old 08-26-2003 | 07:58 PM
iroczman380's Avatar
87 Iroc Camaro............ 12 second recipe
383ci
10.6.1compression
5.7 rods,
scat 9000 crank,
speed Pro Forged Pistons (10cc dish),
Vortec Heads, 64cc (2.02/1.60 valves),,,(Pocket ported) and bowl cut, cleaned up and polished combustion chambers.
Vortec Tpi Base
AS&M Runners,
Fully Ported Plenum
58mm Throttle body,
24lb SVO injectors.
Comp Cams 268H 454/454 lift with 218/218 duration @.50
110 lobe seperation, corrected lift 1.6 rocker---480/480 lift, i think
Crane Gold 1.6 Rockers,
Morley Pushrods,
CCR Lifters
Edelbrock Water pump,
B&M Aluminum Flywheel
2200 Stall Conveter,,
3.42 gears----with positraction
Hedman 1 3/4 Headers Jet Hot Coting,Custom Side Exhaust 3in pipe into Flomasters.,
Hei Distributor,,
Custom Chip
Any Idea on what this would run??? Im hoping for mid 12's with some upgraded suspension, and so on. maybe with some nitrous drop it into the 11's.
This is going to be a torque monster.
All I have left to buy are the roller rockers, lifters, and vortec tpi base. Everything else is assembled and ready to go.
Pics of the motor before heads were installed at this location:
http://weshopkins.tripod.com/iroczman/id4.html
Well ill have it in soon, and then ill post track times, but just wanted to here what you guys thought, and maybe get an idea on what it will do at the track!!! All suggestions are welcome
Old 08-26-2003 | 08:40 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i would have used alittle more cam but it sounds like a real nice setup
Old 08-26-2003 | 09:29 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
What a POS looking IROC with that stupid bra, JK . Hey all you need are the ported heads and your rdy to go.
But you really need to look at those rear end gears and get some 3.43s or 3.73s, but first try out those stock 3.23s you may just like being able to cruse at 105 at 2500rpms
What were your plans for the tranny, a built up 700r4 right? with shift kits and corvett servo?
Old 08-26-2003 | 10:42 PM
For the trannyy, welll i know it wont hold long, hopefully a good thousand miles maybe So i can buy some time to save some dough. I had aamaco quote me 1200 to build my tranny to hold 500 ftlbs of torque. But I can buy a new pro built tranny for like 750, and then have certified swap it in for 200 bucks, which is cheaper. Im not sure what ill do yet.
Well the gears, I dont want to go to much higher then 3.42's or 3.23's cause the car is already gonna have tons of torque, and just adding 3.73's and higher will just spin um, I just hope nothing breaks or twists!!!
Yeah as far as the cam goes, I could have used more cam, and thats still an option, but i want this to be a street machine, that can be driven daily. I think the cam I chose, probably should of had more lift now, but i still am set on the duration. I feel that if i go higher like 224/230 duration at .50 then i will need like a 2500 stall, plus the max hp --rpm will probably be at like 5900-6200, well thats fine and dandy and all, but I dont know if the ltr setup, (tpi) will hit that high, i doubt it. So by adding more duration, Im waisting horsepower that i could be using. I probably could of gone a tad higher like 218/224 but oh well. Well see how this cam does. That 110 lobe seperation thogh will give me nice mid range..
Well any suggestions are great, Im still trying to get an idea on what this sob will run!!!!
Theres some 5.0's around here runnin high 13's that think there bad, but thats all gonna change soon!!!!
Old 08-27-2003 | 09:32 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I would not put much more than 450 HP on a Scat 9000 crank. Go with a 4340 forged crank especially with nitrous. I'd go with the LPE219 cam. 12's should be no problem.
Old 08-27-2003 | 12:56 PM
you wouldnt go over 450 horse with a scat 9000 crank???
My buddy has a 69 camaro and is using a scat 9000 crank, hes pulling at least 500 horse with no problems,
also did you see that article in the chevy magazine, they tested a stock 350, bottom end with nitrous and it held up amazingly.
They went all the way to a 325 shot and it still held. But the 425 shot blew it.
They were pushing 650 horse power and thats on a stock bottom end!!!
Thanks for the advice, but if I ever even get 450 horse to the wheels I will be surprised. A scat 9000 should be good. Plus I already have the entire bottom end done and assembled. It is a short block, so I really dont want to go to all that work to replace it. The cam though I can change
PLEASE GIVE ME THE SPECS OF THE LPE219 cam and where I can buy it!!! thanks
Old 08-31-2003 | 10:15 PM
robert1's Avatar
If you can do your part, 11's will be easy with that setup. Chevy Hi Perf did a build up on a 355, with less than that, and got 12's from it. They also shifted out at 5700, to get the best times too. Watch the quench area though with that high a CR with iron heads for detonation problems.
Old 09-02-2003 | 06:14 PM
88gtagearhead's Avatar
219*/219* duration at 50
.560"/.560" with 1.6 rocker
112* CL
315 bucks at lingenfelter.com
Old 09-03-2003 | 12:05 PM
Ricktpi's Avatar
I had planned to use the 9000 crank but, after hearing several complaints on the durability of the Scat 9000 I asked my engine builder about them. He said after about 450 hp the 9000 crank will start to wobble, which will eventually lead to failure. He won't even consider a 500hp plus motor with one in it. BTW, thats flywheel HP, not RWHP. Here's a link to the LPE cam http://www.lingenfelter.com/lingenfe...24&pf%5Fid=489
hectre13
Car Audio
26
03-03-2022 05:38 PM
LT1Formula
10-08-2015 08:34 PM
meeklay812
10-01-2015 03:46 PM
dusterbd
09-29-2015 08:40 AM
Badass355ciz28
09-28-2015 08:31 PM
Quick Reply: 12's with this setup????
