Car Very Hard to Start When Cold!!
Old 08-26-2003 | 02:27 PM
Ringmaster72's Avatar
Car: 1989 IROC
My car seems to have a lot of trouble starting when it is cold. It will turn over a while before even trying to start, then it will usually just try to start and shut back off. Then it will usually start up once I try it again, but it stumbles at first. Also, if it has sat a couple of hours, like when it is still lukewarm, sometimes it will not start at all, it will just sit there and crank until the battery is dead. But, if I pull or push it the stupid thing will start right up. Please help me, this thing is pissing me off.
Tim
Old 08-26-2003 | 05:49 PM
Car: 1989 IROC
TTT
Old 08-26-2003 | 08:12 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
What is your fuel pressure? Is it low?
I know that if you put a cam/heads in your car you need to recalibrate the chip for the startup circuit. Your car is moving more air and thus needs more fuel for the corect cold start mixture. My acts like it has a carb in the winter. It kind of acts like yours but it does always start, just runs crappy until it wams up.
How fast is your starter turning over? If it's going too slow your starter may be going out too......
Old 08-27-2003 | 06:02 AM
Car: 1989 IROC
The starter is fine, it turns over well. I have most of the stuff to burn my own chips so I guess I can give that a try when I get started and hope that it works. Is there anything else it could be?
Tim
Old 09-03-2003 | 02:27 PM
karrlives's Avatar
start problem
check your fuel pump mayb its going bad
I have a 89 trans am with a 305 tpi with 5 speed
had the same problem as you and it was the damn fuel pump
what your fuel pump might be doing is that it is suckin the fuel into the pump and spitting it back into the tank you might need 2 replace the pump.
that was theproblem with mine fixed it right up
karr
Old 09-03-2003 | 04:48 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Is there a heavy-duty or better pump available than the stock OEM version?
Old 09-03-2003 | 07:12 PM
karrlives's Avatar
www.jegs.com
carries high flow fuel pumps
KARR
Old 09-04-2003 | 09:24 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Cool! Thanks--I'll look into that.
Azrael91966669
25
06-20-2017 04:04 AM
Wade787b
09-29-2015 01:15 PM
86Base
08-08-2015 01:34 PM
mustangman65_79
08-08-2015 12:07 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Car Very Hard to Start When Cold!!
