fuel pressure psi with SVO injectors
Old 08-25-2003 | 11:54 PM
TPIMonteLS's Avatar
Transmission: Automatic!
On a relatively stock 5.0 TPI motor. Has headers, thats about it. I installed SVO 19# injectors, and the fuel pressure reading is at 42 psi. I got a barely used Accell regulator from a buddy of mine as well for future use....now Id like to know is there a recommended psi that I should be at with the SVO injectors, or is the 42psi its at now fine? TIA.
Old 08-26-2003 | 09:55 AM
88TAJeff's Avatar
Car: 88 T/A
Do you have a scanner/ laptop?
If you did then I guess you could watch your BLM's at idle and driving around, adjust it accordingly.
9192camaro
16
02-03-2019 12:21 AM
pimp2303
07-27-2017 02:03 PM
mdtoren
08-16-2015 05:45 PM
Kaweh
08-09-2015 02:54 PM
Quick Reply: fuel pressure psi with SVO injectors
