Problem remains.
Old 08-23-2003 | 02:48 PM
Cybnext's Avatar
Problem remains.
Well, the car continues to die; usually when I hit a bump, turn the steering wheel or put it in gear (this one usually only happens when putting in drive). We already replaced the starter, we've tried 3 different batteries, all of which still get the problem. Anyone have some answers? Or maybe you'll need more detail. Oh yea; 1991 Z28 5.7L
Old 08-23-2003 | 02:54 PM
Morley's Avatar
Short or bad ground to either the ECM or the distributor would be my guess.
Old 08-23-2003 | 04:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What are the idle RPM's at in Park/neutral?
Old 08-23-2003 | 04:53 PM
Cybnext's Avatar
I think they are right around 750, I'd atleast be able to tell you between 500-1000.
Old 08-24-2003 | 12:23 AM
Cybnext's Avatar
ttt
Old 08-24-2003 | 07:13 AM
Powerlover's Avatar
You may want to check the wires inside your steering column. If you have a loose wire in there, or in your console,you could possibly have that problem. As has been said before "Check all your grounds!!!!!!"
88rscamar0
09-23-2015 09:08 PM
pjsparts
09-17-2015 01:28 PM
Ranbo108
09-09-2015 12:20 PM
383cam
09-09-2015 06:01 AM
andy74
09-03-2015 08:41 AM
Quick Reply: Problem remains.
