idle too high sny ideas
Old 08-21-2003 | 02:54 PM
TABBOO's Avatar
Car: 87 T/A
I have an 87 TA 305 TPI, flowmaster exhaust, airfoil,K&N with cold air induction, ADS superchip. I am having a problem with fast idle, when the car starts it idles at about 750 rpm but then quickly goes up to 1000 to 1200 RPM. it idles there in park (automatic ) & idles about 750 - 800 RPM in drive. I have repalced the TPS, IAC and adjusted minimum air. Anybody have any ideas on a fix HELP!!!!!!!!!!!!!
Old 08-21-2003 | 03:02 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just leave it there, be glad its not stalling on you.
Old 08-21-2003 | 05:03 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
check ur TPS volatage, maybe you have a vacuum leak,or possibly an intake manifold leak..?
Old 08-22-2003 | 07:48 PM
TABBOO's Avatar
Car: 87 T/A
I have since posting drove the car for more than just a short drive, the idle corrects itself to about 550 RPM in drive. I have a
180 degree thermostat maybe it just has to get good & warm
I am not quite sure why.
Old 08-22-2003 | 09:47 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
That's how they are designed. It should go away after a few miles or a few minutes, whichever comes first.... Kind of like a choke on a carb...... That's just your cold start injector kicking in.... I believe it goes off after the engine reaches 100 degrees.
Old 08-22-2003 | 10:03 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Yep, my car does the same thing and it pisses me off. When I put it in drive, the damn transmission makes a loud clunk and whoever is standing by my car at the time is all like "You're transmission is messed up"
I wanna slap 'em with a large trout and tell them to stfu, they don't know whats goin on.
[/endrant]
Old 08-23-2003 | 03:52 PM
TABBOO's Avatar
Car: 87 T/A
I feel the same way when the thing clunks when I put it in drive.
Really sucks at a car show!!!!!!!!!!!!!!
Maybe I should go back to the stock thermostat, but I really hate to give up the advantages of running cooler. Every little bit helps
like the small gain from the throttlebody bypass.
Thanks for all the replies. If anybody has any more comments I would certainly welcome them:hail:
Old 08-23-2003 | 06:55 PM
Transmission: t-5
the thud is just the transmission mount isnt it.
Old 08-23-2003 | 08:47 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Limp home mode runs around 1100 rpm idle in my car. If you have another chip that you can run in the car i'd go ahead and try it. I doubt its your problem, but it may be worth a look if your out of ideas.
Old 08-24-2003 | 09:33 PM
Captain C's Avatar
Car: 1985 IROC-Z
The thud is your engine running too fast when you slam it into gear. Let teh car idle down before you put it into gear and everything will be ok. After the car has been running 15 seconds try revig the engine slightly just like you would to kick the choke off on a carb. That will usually kick your engine RPM down in this case as well.....
Don't get in too muh of a rush to take off in a cold car. Teh engine oil needs to heat up first as well. If the oil isn't warmed up some, it may bypass your oil filter (way bad!!!) until it does. Not to mention that it doesn't do your bearings any good either......
Old 08-24-2003 | 10:59 PM
Transmission: t-5
oh yeah,the thud could also be a bad thrust bearing.
Wade787b
09-29-2015 01:15 PM
86IROC112
08-21-2015 07:20 PM
IroczFan
Carburetors
08-18-2015 05:19 AM
perZ
08-15-2015 01:17 PM
Quick Reply: idle too high sny ideas
