Upper Radiator Hose for HSR
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I am installing the HSR on my car and I need a new upper hose. I have searched and could not find anything. My car has a Griffin rad. with larger than stock inlet on it. What rad. hose will fit? An earlier Camaro? Maybe a TB Camaro hose? Let me know. Thanks
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
GM High-Tech Performance specifies a hose for an '85 carburated Camaro. This is what I used, but the hose had to be trimmed to fit.
Yep I had to use a hose for a carbed engine as well. How much bigger in diameter is the inlet on the radiator? Get the measurement and go to autozone and see what they have that follows the TBI hose. Remember that the TBI hose does have to get cut so keep that in mind when comparing sizes.
Car: Guess
Engine: Crazy 8
As always gentleman, you have been helpful. I will go to the parts store and see what they got...
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
go to www.stealthram.com i went to advanced auto parts and got a flex hose with 90* end for the radiator side #12228. also send me a pic and info on your car so i can add you to the HSR CARS section.
Car: 1982 Z28
The thing I didn't like about the carb'd upper hose was it wasn't shaped right for serpentine belt accessories. The part that runs along the radiator and makes the 90deg turn onto the rad fitting was curvy and threatened to rub on my alt pulley.
The TBI hose was shaped identically to the old TPI hose on that end, dropped right into that "U" shaped molding on the upper radiator mount, no problems.
Check this pic:
http://members.fbody.com/kevinc/hsr/Mvc-007f.jpg
Check this pic:
Car: 87 IROC-Z
Engine: 383 HSR $8D
For what it's worth...85 Carbed Upper hose is the same p/n as the TBI hose. I searched them all looking for one.
Pac J
05-17-2020 10:44 AM
