Some pics of my engine
Old 08-17-2003 | 10:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Here are a few pics of my newly assembled engine. Not quite done yet, but figured some my like to see my progress...
Old 08-17-2003 | 10:14 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Old 08-17-2003 | 10:15 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Old 08-17-2003 | 11:49 PM
87Formula4bbl's Avatar
Car: '87 Formula
Lookin' good!
Old 08-17-2003 | 11:52 PM
bigals87z28's Avatar
Car: Check The Sig
nice pics... but where are the specs on the engine... or is it all hush hush? sweet set up man! looks good
Old 08-18-2003 | 06:16 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
He He!! I was pretty tired last night, working late and trying to get this motor together. Here is some info for ya.
Its a 385 cid, Cola 4340 stroker crank, Eagle 4340 Hbeam rods, SRP dished forged slugs, Comp Cams blower cam. It has exactly 9.3:1 compression ratio. I am building it to be a ballsy blower motor. I will be posting some more pics once the heads and intake are in place. I am using AFR 190s that I ported, and the HSR will take its place on top. Hopefully I will be able to install a blower within a year, but that may not happen for longer because I want to do some other stuff to. The car looks good, but it is in serious need of a paint job. Plus those ASCD hoods have been making me itch. I think some cosmetic work is in order before the blower makes it. THanks for the interest guys. Later...
Old 08-18-2003 | 07:19 AM
Car: Check The Sig
89irocbeast is doing a similar set up.. i belive his is a 355, but is going with a HSR and nitrous set up. Im not sure of his internals, but he is going with a blower/HSR set up like yours... you think the AFR 190 might hold you back from deep breathing even with the blower? just a thought... i could be wrong...
Old 08-18-2003 | 02:44 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
No, they will work just fine, I think. I have ported them a fair bit. They are a great head out of the box, but there are a few areas that I work in. My mode of thinking with blower motors is to build up a strong foundation and a balanced combo, then put the charger on it and let it do the work. I figure I will have about 400 or better ponies NA once its tuned. With a good ProCharger, it should jump up to 550+ neighborhood. I think I am going to go with an aftermarket computer though. What do ya think about that?
Stay tuned; should have the engine assembled completely by the end of the night!
Old 08-18-2003 | 02:51 PM
Car: Check The Sig
if you have the money, i would go with an aftermarket computer... but with everyone in the DIY board doing tons of crazy stuff, im sure you could do a lot with teh stock computer. Aftmkt ecm's can be tweeked like a OBDII system and just need a laptop to reprogram fuel curves and other tuning tricks. Id look into it, and also ask aroud the dfi board what would be best for you.... 550+ hp!!! oh yea... sounds like a sweet **** car!!!
Old 08-18-2003 | 04:56 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
I have been burning my own chips since I first learned about TGO. IIRC, the article Trax wrote about beginner prom tuning was how I found TGO. Another thing that I am going to be looking into a lot is the Sy/Ty computer swap. I have read from the 730 ECM it is a breeze of a swap. I do like the idea of just using a laptop to tune the thing though!! We'll see once I get the blower...
Old 08-18-2003 | 08:12 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Update
Old 08-18-2003 | 08:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Old 08-19-2003 | 12:39 AM
Car: Check The Sig
is that the hydra rev kit on thoes lifters? Ive heard about them, but havent heard anything about them... if that made any sence....
Ok, try again....
I have heard of the product and what it does, but havent heard any feedback on it and if its good or not other then what i read. When do you plan to get it up and running? (read: when is there gunna be some sound clips!?!?) Cant wait to see the whole package. what kinda trans and rear you gunna put in? gears? TC if your gunna throw in an auto?
Old 08-19-2003 | 06:41 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Yes, its the Hydra Rev. The idea behind it is that the springs apply pressure directly to the lifter body. This keeps the lifter in constant contant with the cam. It is very helpful because the valve springs would need to be very strong in order to control the valves at higher RPMs. Using really strong springs with hydraulic lifters won't make them long for this world. With the Hydra Rev, the valve springs can do their job better and the Rev kit will keep the lifters under control. But this will be my first time using it...
Should be putting the engine in today, but I don't think it will all be running for about a week. I have to go back to work tomorrow and then I start school Thurs.
I am running a TH350 with 3000 stall. The rear is stock, 3.42 geared open diff. I am planning to look into the G-Force transmission upgrade for my T5 though. And one day I am going to get a 12 bolt rear...
Old 08-19-2003 | 09:41 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
More progress
Old 08-19-2003 | 09:42 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Reddeath210
10-06-2015 08:20 AM
project89
09-24-2015 06:38 AM
Linson
08-21-2015 02:12 PM
bradleydeanuhl
08-12-2015 11:48 AM
BrianI
08-09-2015 11:52 AM
Quick Reply: Some pics of my engine
