Where does this vacuum line go?
Car: 92 Z28
Engine: 357 TPI (L98)
Hanging from area around bottom of throttle body and broken off after 6 inches of vacuum line. where does this go? Engine is '92 TPI 350. Thanks.
Car: 92 Z28
Ooh, maybe. I cant remember correctly, and the car is not here at the moment so I can't check. Assuming this the line I'm talking about, what two points should it connect? Thanks.
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Follow the vacuum line from the EGR and they both plug in to the same connector near the coil/rear left of intake manifold.
The other end connects to the driver's side/front/bottom corner of the TB. There is a nipple fitting that points downward.
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
That line gets real brittle from the heat. Mine snapped real easy. They are not that spendy from the dealer.
-Schultzy
-Schultzy
Car: 92 Z28
Well I just removed my EGR solenoid - where do you suppose I tap it into? Should it be connected to engine vacuum all the time (or is it a source of vacuum itself?) Or is this a function of the EGR system (Which I dont have anymore) and I should just cap it off? Thanks.
Doobie52
09-11-2015 06:19 PM
