What are the TPS readings?
Old 08-10-2003 | 03:38 PM
Ovrclck350's Avatar
I jsut checked mine....it's reading .65 at idle and 4.33 at WOT.
Car runs ok, I was just checking it. Are these values off?
Old 08-10-2003 | 07:03 PM
KYL98's Avatar
Car: 1991 Z28
I think it should be about .52-.56volts....I set mine at .54..right in the middle. Runs fine. I wouldnt worry so much about the WOT value...as all sensors are a little different. The inital reading is more important....
Old 08-10-2003 | 09:55 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
seems like close enough numbers.
Old 08-11-2003 | 05:31 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
90-92 are supposed to zero themselves everytime you start the car. My 92 GTA sits at .65 on startup.
Old 08-11-2003 | 01:26 PM
Z_Ghost's Avatar
Yes with the SD computer you do not have to worry about it as long as the TPS is good.
Old 08-11-2003 | 06:15 PM
billyhoss's Avatar
sound be ok. mine is around that mark too in a 91 z
Old 08-18-2003 | 03:18 PM
Krag's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 w/TPI
Transmission: 6-speed
I am running a '730 ECM that I converted a 1988 MAF to SD and you are saying they automatically re-set? I tried to adjust it and the 'resting' position voltage is 1.7!
Is this right? Don't seem like it..
Old 08-18-2003 | 09:44 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
well... not to steal a post... but mine reads right @ .54 at idle... but when going to WOT... i only read 1.17... should mean bad TPS right... but the car does go to WOT... block learn cell (maybe wrong term here so bear w/ me) goes straight to 15... so the car is reading WOT... any clues?... we put in a new TPS and it did the same thing...
J-money
01-04-2019 09:45 AM
Linson
09-21-2015 01:08 PM
pjsparts
09-17-2015 01:28 PM
TrevinE
09-14-2015 03:20 PM
Quick Reply: What are the TPS readings?
