EGR Soleniod vacuum Question.....
Old 08-07-2003 | 08:48 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I must screwed something up when i was running my vacuum lines and need to know where the lines run...... One i know goes to the EGR Valve itself and i thought the other one went to the charcoal canistor. But when i picked up the EGR Soleniod harness i relized the other line is way to short to reach and is molded like it connects to something on the drivers side......Were does the other vacuum line go to ?? ....The set up i am dealing with is off a 89' IROC. Thanks
Old 08-08-2003 | 12:14 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
It could go to the cruise control circuit, or possibly the PCV valve...
Old 08-09-2003 | 05:18 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
It goes to the vac port on the bottom of the throttle body.
Old 08-12-2003 | 08:30 PM
Car: 92'Camaro RS
Engine: a loud one
Thanks...Okay...that explain why i didn't find any vacuum line to go under the throttle body....Now , which vacuum line goes to the purge canistor? ...I already have one line coming from the passangers side of the throttle body but isn't there another vacuum line?
Pac J
05-17-2020 10:44 AM
HoosierinWA
10-07-2015 10:15 AM
jaridjohn
10-05-2015 07:01 AM
djmarch
10-02-2015 10:41 PM
Quick Reply: EGR Soleniod vacuum Question.....
