Do you guys think this will actually have any benefit?
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I saw this http://www.top-downsolutions.com/pro...products_id=97 for sale today on Top-Down solutions website. It seems to me that this really wouldn’t do much if anything. What do you guys think?
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Bog, what the heck is that? Isn't that the name they called the swamp in the 80's movie Labyrinth with Jennifer Connelly? :sillylol:
Really, this part sounds like a load of bs. Maybe it's a band-aid for a weak fuel pump or something?? I would think that the tornado would be a better value for the money.
I can understand that you TPI guys are confused. Perhaps if you guys visited the TBI forum or did a search in the TBI forum you'd understand the vacuum-delay valve, which is used in conjuction with the vacuum-adjustable fuel pressure regulator. Please re-read the description. I've revised the description to help end any confusion as to the intended application. I discovered that the VaFPR would flood the engine dumping too much fuel when the accellerator was floored. Many TGO Members (including myself) have already installed vacuum-delay valves in congunction with the GM 17113186 VaFPR with good results. If you aren't using a GM 17113186 VaFPR (which is used only on GM TBI engines) then don't order it.
Thanks, Lon
Thanks, Lon
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
He has a TPI car though therefore this is worthless to him. It may help TBI cars but that's not what he has and that's not the Forum he posted it in
Car: 91 Z28
Engine: Forged 383
Thanks for pointing that out, Danny. You're right, I was mistaking the tbi for tpi, maybe I need glasses...
