24lb injectors
Car: 1986 Trans Am
Engine: 5.7L TPI
24lb injectors
i'm currently building my 350 and am almost ready to drop it in but i need to find some 24lb injectors for cheap, preferably used and under $100 can anyone help me find some ? or is anyone selling ? all i have is my stock 305 injectors
Car: '88 Formula
Engine: 355cid
Since we are talking about injectors here can somebody tell me if the SVO 24# injectors are the same as the Ford performance 24#injectors that Summit sales for $219? Need to know this before I buy the set from Summit.
Car: '88 Formula
Engine: 355cid
Oh, come on I know somebody out there knows the answer to this question about the SVO and the ford performance injectors. Are they one in the same or what?
Car: '88 Formula
Engine: 355cid
No, this is an injector question as a lot of us 3rdgenner us various injectors. A lot of people recommend the SVO 24#injectors which is Ford but I need to know whether or not the Ford performance 24# injector is the same. So this is the right forum.
1 Post
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
They are the same, SVO means "Special Vehicle Operations", it is like there highest performance vehicles. I got mine from Jegs for $219 also, and the box says 'Ford Performance'.
Car: 1991 z28
Engine: l98
But, isnt it true that the lb/hr on svo injectors are rated at the psi that for uses? Their fuel system is rated at like 36psi. Correct me if im wrong, but wouldnt a set of #24 lb SVO injectors be rated for more like 26 or so? Then if thats the case the 19's would be good for like 21 or 22#'s . Im a little fuzzy on this but I am lookin at the 23# accells to get as close to a stock replacement for my l98. Dont want 24's cause i dont have want to do any prom work as of yet. And I figure i could use the 21's and get an AFPR and crank up the pressure.
1 Post
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
yeah the SVO injectors have a conical spray pattern instead of GM's straight squirt design they all seem to have.
the svos are rated at a lower pressure as described, 24# flow more like 27# @ 44 PSI.
they have only 1 lockring land however, and its higher up on the injector. this means when you put the thing into the fuel rail you dont have to push it near as far into the hole, i would recommend new Orings too.
here is a pic of a 24# SVO injector from a 99 Cobra. See how high up the snap ring is? if you check the factory injector its almost 1/2" lower. the injector still sticks out into the manifold just as far, but its overall length is slightly longer.
thejimsterz28
09-15-2015 04:37 PM
