Idle Problem. HELP!!
Ok I just recently picked up a 91Z w/ 350. It runs great and is damn fast for being bone stock. Anyways, when I'm sitting at a light in drive the idle has like a miss to it and sometimes it stalls. Here's what I've done so far. Tune-up, new EGR, cleaned IAC, AFPR set at 48 PSI(by the way still had the idle prob w/ the stock FPR), etc. Can anyone think of anything else? No check engine light.
did you adjust / mess around with the iac and tps at all?
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
