12 sec recipe
Car: 1988 GTA
Transmission: TH350
12 sec recipe
I got an 88 GTA 350 TPI A4.
When it was roughly stock (exhaust, weld prostars, ET streets, 2.77 gears), ran a low 14.
Dropping in a 3000 Stall Converter, 3.73 gears, Hoosier Drag Slicks, and a TNT 150 shot. Will have a window switch so i can launch on the bottle and shut off before I shift. I will also be porting out the plenum, possibly the manifold.
Just trying to get an idea if I can hit mid to low 12's with this setup.
Thanks to all who respond.
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
NOS is inconsistant. I think you might see 12's, sometimes. Or you might see your rods jetting through your oil pan.
Just something to think about.
I think you have a strong base for a n/a car. I've never been a fan of nitrous, being a drag racer. Its too inconsistant and WAY too risky for my budget. I'ld hate to see $5000 worth of motor Die 'cause I gave it the bottle, but hey, if you want it, GO FOR IT
Car: 92 Camaro RS
4.10 gears seem to be the best "All around" gears for Our cars. They will run a quarter great, but still only run 2400 RPM in O/D at 65mph. A good friend of mine has that setup in his 89 bird, and it seems to work alot better than my 3.73's.
I run high 12s with the mods in my sig and a slipping tranny - no stall or draglites for me. Assuming you're running the stock cam, I would get a 2500-2800 stall, 3.42 gears (you will run out of RPM with 3.73s with a stock tire height), box your stock LCAs and get relocation brackets.
P.S.- The window switch wont shut off nitrous during a shift - dont believe me? try it and find out - or you could search the power adder boards.
Car: 92 Camaro RS
Re: 12 sec recipe
The 4.10's were on a 16" rim, I dunno about a A4, but he run's in the high 13's with 4.10's and doesn't top out at all. Another one of my friends has something like 4.88's in the rear of his TUBBED Pro Street 85 'maro. I don't know the exact gear size, but its something high like that in a custom 9" rear with Hoosier Slicks.
Car: 98 Camaro SS
Transmission: M6
Inconsistant? You must run a garbage setup with no control then.
Bottle pressure builds consistency. Maybe you're basing your comments on kits from 10-15 years ago when no one really knew what they were doing yet.. but they have come a LONG way.
Car: 87Z
Engine: ?
Transmission: A4
Car: 1988 GTA
Transmission: TH350
Why wouldn't a window switch shut off the nitrous. It made to activate a circuit at a set rpm and then deactivate a circuit at a seperate rpm.
"The RPM Window Switch #121-8956, has two rpm adjustments; one to activate a circuit, while the other deactivates the same circuit. This is a great feature to deactivate nitrous before the engine's rev limit is reached." - straight out of a MSD catalog
Plus i will be running all the added safety features on my nitrous setup. For oil pressure and fuel pressure shut off switches.
the combo yo uneed is a loose 2600 converter. Preferably a 9.5" converter.
Run a 150 shot..thats fine, but make sure its a WET kit.
With minor/dopey bolt ons and headers you will be in the 11's with a good tire.
I went 11.70's week in and week out with stock heads, stock cam, SLP runners, 46 psi of fuel, MSD ignition/coil and 1 3/4 SLP headers along w/ 26" Hoosier for a tire. STOCK tranny and converter!!
Car: 1988 GTA
Transmission: TH350
What if a WOT switch and window switch are used together on the same system. Would that work?
If that wouldn't then i guess i'll just have to beef up the tranny to take the punishment.
Car: 98 Camaro SS
Transmission: M6
you can use any number of switches in a series to arm it..
WOT - Window - momentary (push button) - SPST - etc.
it's all based on your personal preference.
I run an electric WOT circuit I made, an on/off (NX panel) and then a progressive nitrous controller...
if you're running a manual car and WOT switch, assuming you let of the throttle for an instant while u shift, it will shut off for that split second. Manual cars really dont need window switches IMO. The WOT switch IS the window switch b/c u lay off the throttle then gat back in it.
Just MHO
Just MHO
rb85TA
26
09-14-2015 10:29 PM
