What size o-rings for TPI fuel rail fittings?
Old 06-22-2003 | 11:30 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I need the size of the orings on the fuel rail both incoming and out where the flex line meets hard line
Thanks for any help
Old 06-23-2003 | 02:29 AM
jodylee8310@aol's Avatar
o rings are specific sizes for the rails and also different in some places, dont fool around and try to install cheap o rings go to the dealership and order them, if cheap ones leak it could cause a fire since its so close to the distributor.should be around $22.00 at the dealership.i know it sounds like alot but just think if you lost the whole car over some little pieces of rubber o rings.DONT TAKE THE CHANCE.
Old 06-23-2003 | 03:14 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
I had not planed on buying rubber orings
local auto store have a very wide varity of petrolum grade orings for a buck or less a peice
I dont have the older ones to compare and I dont feel like taking the hard lines down to match
I'm talking about the very begining of hard lines before you get to the rails where the flex first meets the hardline
anyone have a sizes for me ?
thanks
Jed
wruiz
08-13-2015 09:07 PM
Sanjay
08-12-2015 03:41 PM
Armored91Camaro
08-12-2015 09:41 AM
knight72
08-10-2015 09:32 PM
92projectcamaro
08-06-2015 01:20 PM
Quick Reply: What size o-rings for TPI fuel rail fittings?
