Fri the 13th ran over black cat - now no spark, WTF?
Old 06-20-2003 | 09:04 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
No joke, Fri the 13th I was heading home from dinner with a friend when it happened. Was following a car a few car lengths behind when from under his minivan out flies a cat with a white stripe on it's back, OK a skunk but black cat sounds better. Had no time to swerve and didn't want to at 70 mph so I let off the gas and ran over it. It made less noise than I thought so I hit the gas to take off and I noticed the car is not accelerating, eng was dead. I coast off the e-way and stop, put it in park and try to start it, turns over but no fire. Could smell gas and had fuel pressure so I pop the coil wire to check for spark, nothing. It's dark and I can't see sh it so I get it towed home. I have since got under it and no damage to underside, just some fur and flesh. but no loose wires. I have an 89 RCR's old car with a LT1 intake and accel DFI. I am not familiar with the accell wiring but since it controls spark I am guessing it is tied into the ign system.
Does anyone have a wiring diagram of the accell connections they can e-mail me? I want to check out it's connections first before I start before the GM stuff.
Any ideas as to what could have happened, my guess is something came loose in either the ign system or a the accell interface. BTW I am getting poer to the coil but it must not be recieving the signal to fire.
Thanks a ton.
Old 06-21-2003 | 02:37 AM
chevyboy07 91's Avatar
try the ignition amplifier. It is under the dist. cap. It's very common for them to go around 120,000 miles or so. every 3rd gen I owned did it at approx 120K. Costs about 30 bux or so and its EZ to swap out
Old 06-21-2003 | 08:48 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Thanks, I'll check it out.
Old 06-21-2003 | 10:07 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Yes...the ignition module would be my 1st choice too...
BTW...running over a black cat on the 13th... That won't curse you at all
Old 06-23-2003 | 02:20 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Jut my luck I guess.
I ran into my no turn over problem again and fixed that by bypassing the f'n relay, I ran the ign wire directly to the gear position sensor and got crank right away. This leads me to believe that the Accell computer might be toast. Can anyone tell me what wire from the computer triggers the dist? Has to be some wire that connects to the dist in order to control spark adv. A wiring diagram for the accell computer would be of great short and long term use to me. I'll check their website.
EDIT:
Found it on their website, should have looked their to start.
Old 06-24-2003 | 02:17 AM
dang, this could get complicated...best of luck man! Im good at wiring but i friggin hate it.
Old 06-24-2003 | 10:43 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I can handle wiring as long as I have a diagram, but once you get into someone else's custom work, all bets are off. Just to add insult to injury the starter decided to stop cranking and just make a loud clunk noise. On the bright side I'll know the Formula as well as the vette before I am done.
chazman
08-28-2018 03:25 PM
Azrael91966669
25
06-20-2017 04:04 AM
NufNuffZ28
08-14-2015 09:12 AM
Quick Reply: Fri the 13th ran over black cat - now no spark, WTF?
