Strange igition prolem
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
Hey all; I have recently gotten a very strange ignition problem outof my car. It is a 1988 Camao SC with a 1985 305 TPI from an IROC.
The valve seals are bad, so I installed these little things called "spark plug non foulers" to keep oil from screwing up the plugs until I can do the seals. The non foulers are little screw in adaptors that bring the plug out a little bit from its original position to keep it away from dripping oil from the valve seals. They have a small hole at the end to allow air/fuel mixture to be ignited.
I put in Bosch Super plugs wen I did the spark plug change. The #1 and #2 cylinders dont have these foulers cuz they are OK. All other 6 do.
After I installed the non foulers, by car started to act as if the firing order was screwed up every time I started her, hot or cold. I checked that many times; all OK. The car never did that before the non foulers.
Today, the car started gettng a dead cylinder every time Istarted her, hot or cold. Acts like a plug just aint even working. However, here is the funny part: a minute or so after I start her, thi problem vanishes and she is OK with no problems.
I replaced the MAF and TPS recently, as well as the coil and rotor. Wires are just over 1 year old and the plugs are brand new.
Can anyone help me identify this problem and tell me what I might be able to do to fix it? Thanks in advance!
11 views and no help? what gives? someone has to have an idea of whats up.
kev
kev
all 6 cylinders re fouling up on oil. i have to do valve seals. but i just bought some ac delco plugs of a higher heat range, and will install them tomorrow w/o non foulers. see what that does.
kev
thanks for your help
kev
