Baby won't start...
Old 06-16-2003 | 09:23 AM
Rand's Avatar
Baby won't start...
So I'm taking a nice, comfy turn in second gear, and suddenly the car is no longer running. Attempt at popping the clutch doesn't spin it back up, and turning it over kicks hard enough to start her, but it just keeps turning and turning without ever even studdering. Has been almost a week now, and same thing.
We verified that we're getting spark to the plugs, so no ignition control module issues. Someone suggested vapor lock, but supposedly that wouldn't be the case with a TPI that's sat for a week. We were going to check the fuel pressure to see if it's the pump. When we turn the key, the pump doesn't sound like it's turning on.
Any other ideas? Looking forward to rolling again.
Old 06-16-2003 | 09:26 AM
Rand's Avatar
Oh yeah, it's an '89 Formula, stock 305 TPI with no upgrades.
Old 06-16-2003 | 09:47 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Injectors?
Old 06-16-2003 | 09:48 AM
FyreLance's Avatar
Oh... just read that you don't hear the pump... if you don't hear it then that's probably it
Old 06-16-2003 | 10:09 AM
Rand's Avatar
Thought about that. The fuses are all good. How can I test to verify they're working otherwise?
Old 06-16-2003 | 10:10 AM
Rand's Avatar
and if it is the pump not running, will it more likely be the pump itself or wiring burnout? Is replacing it the only way I'll know?
Old 06-16-2003 | 07:09 PM
copperhead110's Avatar
I'm not sure if there is one or not, but there may be a relay involved also.
Old 06-17-2003 | 01:12 PM
leirch's Avatar
Check the fuel pump relay, do a search for the rest of the diagnostic procedures on how to determine if its the fuel pump.
Bubbajones_ya
10-25-2015 08:01 PM
Cole Curtis
Theoretical and Street Racing
10-03-2015 12:26 AM
Spyder_TheGamer
10-02-2015 12:25 PM
Luigytico09
10-01-2015 08:46 AM
the_hamturdler
09-30-2015 12:50 PM
Quick Reply: Baby won't start...
