LT1 Inatake mods
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Because I have valve cover breathers and didn't feel like re-routing crap air into my intake, giving me something to clean out of there (like EGR)
The inside of my intake is going to stay nice and clean
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
But doesn't that PCV slot only go from the outside of the intake to the lifter valley? I don't recall that passage going inside the intake anyway. Guess I still don't see the benefit.
I like the job you did on covering the coolant ports.
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
yes it does, but the usual way of routing it is then to connect the pcv back to a vacuum line, which routes it back INTO the inatake, I just have no use for it, so I welded it, if i want it open, a grinding wheel will open it right back up.
Thanks, I took your intake as an example
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
88SS6SPEED
11-11-2015 07:05 AM
