Stealth Ram thread-dyno/track on L98
Old 05-13-2003, 06:00 PM
  #101
OMINOUS_87's Avatar
1bad91Z
What do you mean by total max timimg?
If you mean:
Max Spark Advance: it is 41.8 in the constants
I would not use it as a tuning tool.
The only time I would disable the knock sensor would be at the track but only if I knew my fuel was nailed with a WB and my high LV8 spark was within reason and I was picking up false knock for some reason that I couldnt solve otherwise.
A virgin AUJP base it available at DIY-EFI or Mike Davis site.
OMINOUS_87 is offline
Old 05-13-2003, 10:42 PM
  #102
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Originally posted by OMINOUS_87
Kingtal0n
For the track we will be pulling back low rpm timing somewhat and turning full advance on right at the converter flash point. Gonna start with 31 and work from there based on ET and knock retard.
RedIrocZ-28
You should not have your base set past 6 unless you have made serious modifications to the stock timing curve. I think you may want to spend some time understanding how the timing curve in the chip is actually applied under different driving conditions otherwise your performace will be very poor due to knock retard or worse yet you might break something, over timed and under fueled is an engines worst nightmare.
From what I remember, the car doesn't like to idle at all at 6* BTDC. I think we had it spitting and sputtering at 8* and 10* was so so..... I dunno... this car is weird. I do understand a little how the timing curves work. On the bright side, it is running a bit rich at part throttle so I have no knock showing up. However, I have yet to do a datalog of any race track blasts... hence my reasons for going to flashproms and going to the track in 2 weekends.
RedIrocZ-28 is offline
Old 05-15-2003, 12:33 AM
  #103
esams's Avatar
Let this thread die guys, I'll start a new one entitled part 2 in a couple weeks. Will link to here if you're following it.
esams is offline
hectre13
Car Audio
26
03-03-2022 05:38 PM
Linson
09-25-2021 07:55 PM
FormulasOnly
07-23-2018 08:47 AM
mfp189
09-27-2015 09:25 AM
R3500
09-08-2015 10:12 PM
Quick Reply: Stealth Ram thread-dyno/track on L98
