TPI intake manifold gasket?
Car: 1987 IROC-Z
I am wondering what intake manifold gasket should I gasket match if I'm going to be porting the stock intake??
As some of you know I am porting some stock 305 heads for a project & I don't know what gasket is good to port match to?
I want a gasket that isn't rediculously big & I can use it to also gasket match & port my tpi intake. That way I have extra flow from stock intake to head.
any recommendations?
Also is it even worth using the regular stock intake gasket & port/gasket match that?? I wouldn't be gaining anything from that.
use a felpro 1256 if u go with a 1205 u will have 2 weld the corners of the intake for it 2 seal properly any way the opening dont mean crap on those stock heads all your power is in the bowl and a nice 3 angle vavle job
ambainb
04-25-2016 09:21 PM
86IROC112
08-17-2015 02:00 PM
