Which valve springs with "219" cam??
Old 03-27-2003 | 12:50 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
What valve springs are you guys that have the "219" cam using? I was using Comp 987's but i've been told that they may be to big for the cam. I'm also using 1.6 rockers so i'm getting .560" lift.
Thanks,
Paul
Old 03-27-2003 | 07:04 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I use the 987s with my 219 with an installed height of about 1.750" (recommended). You should be fine with the 987s, they're good up to .600" lift.
Old 03-27-2003 | 11:14 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I've got the 219 cam and 1.6 comp cam prog magnum roller rockers.
I'm running a Lunati spring recommended by and bought through Lingenfelter. I've got the install heights and pressures in the garage if you find yourself needing them.
Part # at LPE: LN0018DBLAS
Price Each: $7.49 (16 @ $119.84)
These shims were required also.
Part # at LPE: 10185066
Price Each: $1.46 ( 16 @ $23.36)
That was about a year and a half ago, not sure what they'll cost now. Also I don't know what cylinder heads you are running, but I had to cut my aluminum d-port gm heads to fit these springs. I'm also running a Lunatic titanium 10* retainer and the associated comp cam locks.
Good luck!!
Old 03-28-2003 | 07:57 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Scorp, have you got the Lunati part number for those? It looks like LPE has them listed under an internal part #. LPE used to sell Comp Cams stuf, I wonder why they switched to Lunati. I e-mailed Tim at LPE but he hasn't sent a response yet.
Thanks,
Paul
Old 10-20-2003 | 01:17 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Sorry to bring this topic back from so long ago, but I was wondering if the spring's that come with the afr heads will be safe with the 219 cam??
Old 10-20-2003 | 04:38 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
They'll work fine if they're set up properly. Personally i'd get get what LPE recommends for the cam though. The ramps on the cam are pretty steep. You can have my old Comp 987's for cheap if you'd like.
Old 10-21-2003 | 06:49 AM
Car: 91Z
Thank's for the tip. I think I will use the LPE recomended spring's, or I might take you up on the offer. I would rather not use the AFR spring's if it is iffy. BTW, I was talking to Carm (stroked81z or something like that) and he was telling me a bit about your car. I am in ottawa so I will send you a PM about those spring's and mabey come pick them up if that's OK wt you. I just wanna know if you are running a LTR settup, or the SR??
Thank's,
Cory
Old 10-21-2003 | 04:18 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I use a very ported Superram. Don't talk to Carm, he's a bad influence
Old 10-22-2003 | 06:30 AM
Car: 91Z
lol, Thank's for the tip.
Cameeeero
09-18-2015 04:00 PM
gta90
09-15-2015 04:00 PM
SLNTSCPE
08-22-2015 09:15 PM
1988iroc350tpi
08-14-2015 07:52 PM
Quick Reply: Which valve springs with "219" cam??
