Tpi Help.....please!!!
Building a 350 .30 over....going into a 88 t/a that originally had a 305 TPI....has a chip installed already....im wondering if I will need to reprogram the computer....and if so where can I get it done....I live in the Chicago Suburbs....im also running a comp cam with 266/276 lift and 500/510 duration with 114 LSA.....any help would be appreciated....oh and im running stock injectors for now.....i ran out of money so i wanted to get things that required pulling the motor done first......
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You can search for ed wright, and talk to him personally (through pm) about it. I think that he is the prom burner for fast chips. You can also learn how to do it for yourself and get that thing tuned for your car. It is better if you are willing to learn.
Sanjay
08-12-2015 03:41 PM
