SuperRam Problems
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
SuperRam Problems
I finally was able to take the car out this weekend for the first time with the SR and l do not like the results at all. All I did was replace the intake with the SR. I feel there is no power and It shifts really bad. I have adjusted the TV cable like 400 times but I get the same results. It shifts really hard. I feel is has to be pulled out a little more but the TB rachets it out only so far. What to do? Also it seems that If i do get power its at about 4000 and nothing below. The chip was burned for the LTR setup but it should be good enough for now with the SR. Any suggs? Anybody have any prom ideas I could run with? Thanks
1 Post
Car: Formula
Engine: 6.0 LSX
I'm half tempted to go back to my Large Tube Runner set up. I wouldnt have intake elbow problems and my STB would accually fit. Oh BTW Heads are TF and the Cam is a 218/224 495/503 112lsa cam.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I dont think you have a bad PROM sor the SR. I changed from LTR to SR with my LTR PROM and got a hugh diff. in performance. My guess is a vacuum leak........
/N.
/N.
1 Post
Car: Formula
Engine: 6.0 LSX
I changed gaskets 3 times cause I thought I had a leak. I'm getting 14in Vacume at idle and its silky smooth at 750. All 3 times witht he same results.
1 Post
Car: 92 Z28
Engine: Boosted LSX
DO you have a laptop and scann software? Thats the best way to check things out.
How about timing?
If you dont have a laptop and scann software. I can bring mine down Saterday and let you borrow it for awhile.( if your gona be at the gathering.)
How about timing?
1 Post
Car: Formula
Engine: 6.0 LSX
i have a Tech 1 And its showing TPS .54 10-15 IAC Counts ,Temp is good. O2 at idle is 090-750 BLMS on the scanner are showing 126/128 130/128 and so on . At WOT its goes straight to 128/128 Timing is at 10*. I havent checked for knock. I'll do that after work today and let you guys know.
1 Post
Car: Formula
Engine: 6.0 LSX
Well I moved my timing back to 7* and I redid the TV cable per Transfixleo's method and it seems to shift better. I'm going to take it out and see how it does.
1 Post
Car: Formula
Engine: 6.0 LSX
Well the car drives alot better now. It shifts like it used to so thats good. No power from idle to 3000 RPM though, but after 3000 it keeps pushing you back farther into your seat. I know I need a converter and I have a 2600 9.5in sitting in my garage but I didnt like it. I just like idling around sometimes.
Car: 04 GTO
Transmission: M12 T56
If it otherwise runs fine and just seems to be a dog at WOT / low RPMs your problem could easily all be found in the tune. Pump shot is probably way off compared to a LTR setup, which would make it sluggish on the transition. Beyond that, just the shape of the spark curve could be making it lazy to say nothing of where and hw you're adding WOT fuel.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would suspect the tranny cable hookup on the side of the SR. When I installed my SR, I remember that I had issues with the TV cable. Try different positions, I finally found I good setting. The standard method did not work for me,, I had to do a little experimenting.
You may be too rich or too lean if it takes until 3000 to throw you back with the superram.
