tpi harness plugins
Both. The purple/yellow is speedometer (not used in Camaros), and the tan/white is for the transmission (although there should be four?). I'll take a look at one tonight if I remember to.
Re: noooooooooooooooooo!!!!!!
Originally posted by badgta
man i cut that..... i thought it went to the tranny... damn it....
Just use wire connectors to splice them back together and you will be fine. Make sure you use good connectors. Might be alittle hard to get to though.
IBrockZ
08-20-2015 12:20 PM
Sanjay
08-12-2015 03:41 PM
