Motor Reinstall...
Motor Reinstall...
Reinstalling my TPI motor in my 88 T/A.....when i took it out i labled all the wires....but i'm still scared ****less....can anyone give me a sequence of steps for reinstalling this motor as well as timing info and all that good stuff....any tips of advice....im going to be running aluminum Vette heads and 10.6 compression as well as a Comp Cam ill give the specs below thanks guys...
Duration
IN EX
266 276
Valve Lift
IN EX
.500 .510
Duration
IN EX
266 276
Valve Lift
IN EX
.500 .510
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Just take it one bolt and one connector at a time,, you should be OK.
For me when I pulled my motor for alot of mods, I took pictures as I did the tear down and pulled the motor. Also, I labelled everything like you did.
Good luck!
Good luck!
