p/n for tpi boot speed density?
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Are you asking about the rubber duct (bellows)
between the plastic airbox and throttlebody?
For a SD (MAP) system, it is GM p/n 10105251
About $15 IIRC
HTH
mike
About $15 IIRC
HTH
mike
Transmission: A4
holy crap! you got any pics of it. I would try the classifieds or a local boneyard before going to the dealer for a new air filter housing. THe dealer might rape you. Also try ebay
Yep, Bottled called it right on this one.. The
plastic "Y" is the same on V6 camaros and
should be easy to boneyard or from one of the
thirdgen.org used parts sponsors at the top
of every page..
FWIW, you can get the plastic assembly from
yearone for almost $500
http://www.yearone.com/serverfiles/h...p?hid=G13AR145
mike
of every page..
mike
1992 Trans Am
05-10-2023 07:19 PM
86IROC112
09-07-2015 01:37 PM
Sanjay
08-12-2015 03:41 PM
