TPI on LT-1?
Old 03-09-2003 | 04:09 PM
Kaas's Avatar
Car: 89 Iroc-Z
TPI on LT-1?
i got a question guys...i have an 84 z-28 5-speed. i am wanting to put in a 350 86-88 vette LT-1 engine in it, and then a TPI system on the Lt-1 heh...anyways...was just wonderin if it was compatable, and also was wonderin how i would go about doing this, (if anyone could suggest some good LT-1 or TPI books for me to pick up that would be great)
Old 03-09-2003 | 04:24 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Umm..... The mid 80's Vettes did not com with a LT1 engine, it was the L98 engine, basically the same as a the Camaro TPI's, only difference was the injectors and on some the heads were aluminum. If you have the Vette engine it should be a TPI, if it is the factory engine. If it isn't, then you will have to find out what the engine in the Vette really is. A TPI intake will not fit on a LT1 long block with out some heavy machine work. If you want a LT1 look into the mid 90's Camaro/Firebirds. Plus I would never replace the intake on a FI Lt1 for a TPI, that is like going backwards on the performance scale. A LT1 breathes way better then any TPI.
Old 03-09-2003 | 04:25 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
No reason whatsoever to run a TPI
intake on an LT1 block.. Either run a
LT1 intake, or get an L98 block..
mike
Old 03-09-2003 | 11:30 PM
Iroc n roll's Avatar
Yeah a couple of things... There were two corvette engines made with similar codes, the LT1 and LT-1. The LT-1 was a carbed motor they made in the 60's I think (anyone know the dates?) and the LT1 is the FI motor made from 92-97. I guess putting TPI on an LT-1 might be a good idea but like Cruzin said, putting TPI on an LT1 is going backwards in technology. Corvettes from 86-88 came with the L98 TPI engine....in fact the real years of L98 vette production are 85-91 I believe. Before that they used CFI (cross fire injection).
Old 03-10-2003 | 12:51 AM
Kaas's Avatar
Car: 89 Iroc-Z
so....which has more potiental, the L98 with TPI or the LT1 (i guessin the LT1, just had to ask to make myself look stupid lmao)
Old 03-10-2003 | 07:53 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's possible to run TPI on an LT1, although anybody that does it probably needs his head examined. Ligenfelter produced the Super Ram for the LT1 for a short period of time, and some of the bases are still floating around. If you can find an LT1 super ram base, you can run a stock/aftermarket TPI plenum and runners with it.
But you might as well keep the LT1 intake and shove a potato up the tail pipe. It's cheaper and will give you the same results.
Old 03-11-2003 | 09:17 AM
bigals87z28's Avatar
Car: Check The Sig
ahh there is no LT1 from 86-88.. never ever. There might be LT1 intake on a l98 block.. but never were they stock in thoes years. there is no need to put tpi on a LT1 anyway.. unless you had a 350 truck engine that was a Gen 2 block, and you didnt have any money to put on a lt1.. thats posible. but i agree that tpi is a step back in the evolution of FI. thats like putting on cross fire on a firehawk....
And here is todays history lesson....the LT1 engine that were back in the good ol'days were found in 701/2 Camaro Z28's and Vettes.. only if you ordered it.. 360 for the camaro, and 370hp for the Vette but the engine was the same... the engine was a wise upgrade because of insurance and emmisions were killin big block power... in the late 80's, early 90's when GM was looking a new RPO for the new Gen II engine, they thought retro and went back to the LT1 code... and The same with the LS1/6 like the LS6/7's found in Chevelles.
Alex
stalkier
12-06-2015 11:25 PM
ChaseDale3and8
09-01-2015 01:49 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
cRoe4
08-07-2015 08:46 PM
Quick Reply: TPI on LT-1?
