Different year TPI parts compatibility
Old 03-09-2003 | 03:15 PM
Nasty_Bird_'90's Avatar
I'm having trouble getting my new L98 to run after the swap and am wondering if I have some compatability issues that need to be resolved. The inake, plenum, runners and rails are '86, the harness is an '86 (maybe 85) and I have an '88 and an '86 ECM. The car is a '90. Do you guys see any conflicting parts here? In case you're wondering the car starts and runs for a second then shuts itself off. Any ideas?
Old 03-09-2003 | 03:19 PM
rezinn's Avatar
You have a MAF sensor, right? I'd use the 88 ecm/chip since it has cold start enrichment, so the cold start sensor will just plug a hole(if you use it). One less thing to worry about.
Old 03-09-2003 | 04:10 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Different year TPI parts compatibility
How about the throttle body? The
man interchange problem is with the
TB/plenun/runner issues and the idle
air passages and cold start injector..
(A '90 TB will not run right on an '86 plenum/runners)
mike
Old 03-09-2003 | 04:12 PM
Bort62's Avatar
Re: Re: Different year TPI parts compatibility
mike
Bingo.
My Guess is that is the problem.
Old 03-09-2003 | 09:09 PM
'88 TB and plenum. I have an '86 TB and plenum too, should I try that?
Old 03-09-2003 | 09:27 PM
Bort62's Avatar
As long as you have got the Cold Start Injector Vacancy plugged on the Base runners plenum ect (wich would be pretty obvious if you didnt ) and You have a Matching plenum/TB setup, then I don't think this is your problem.
Did you use the right gasket on the TB/Plenum? I forget if the 88 Setup is the early or late one.
Old 03-09-2003 | 09:40 PM
CSI Vacancy? I have the cold start injector installed. I'll check the TB gasket. Thanx for the ideas!
Old 03-09-2003 | 09:44 PM
Bort62's Avatar
Now that i think about it, I once used the late TB gasket on a early TB/plenum and it did the exact same thing. It blocked the IAC passage.
It would fire up and die.
I do belive 88 uses the old style TB, too so you might be in luck.
Old 03-10-2003 | 04:49 PM
Hopefully! I picked up a gasket today with the IAC passage. I'm gonna throw it on tonight and see what happens. Thanx guys
jaridjohn
07-08-2024 03:49 PM
Grant2k
07-10-2018 04:01 PM
Sanjay
08-12-2015 03:41 PM
Fronzizzle
08-09-2015 01:15 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: Different year TPI parts compatibility
