395 cubes & Stealth Ram
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Would the Stealth Ram lend itself better to a 395 cu.in SBC vs the SuperRam???? (that I already have)
I was thinking that with 395 cubes, I'd have plenty of torque and bottom end,, and I thought that maybe the SuperRam might be a restriction at top end. So, does the Stealth Ram fit into my logic better?? I would expect to be shifting at most 6,000RPM, but maybe only 5600RPM. Right now, I let the 700R4 shift itself and it shifts at about 5400RPM.
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Doc...I say...YES!
I believe that the Stealth Ram out of the box flows more than a mildly ported Super Ram...
For the money...it is a great deal...IF you don't have to worry about emissions...Thank Jebus that MN dropped their emissions requirements a few years ago...WOO HOO!
That is why I went with one for my 406...I already have too much low end and not enough traction.
Car: 1990 Iroc-Z
I'd have to agree with that. The HSR probably outflows the Superram. Both are great intakes but the Superram is designed to maintain lowend torque, while the HSRs first priority is highend horsepower. The reason it is so dirt cheap is that all holley did basically was convert a tunnelram to EFI and that also explains why it is not emissions legal. If Holley had to make it emissions compliant I'm sure it would cost about the same as a superram.
In short, you should get the HSR.
Car: '87 IROCZ
Engine: 395 ZZ4
Well, that was what I was thinking. 395 cubes will get me the bottom end torque, and the HSR will get the top end that I have been missing on my IROCZ. I am re-reading the GMHTP article again as I write this.
I have an '87 with the remote coil,, so I assume that I can retain that distributor if I use the HSR,, Is that correct?
Car: '87 IROCZ
Engine: 395 ZZ4
I have an '87, I think my car already has the small distributor because I have the remote coil.
I re-read the GMHTP article and I was a bit annoyed at all the nick nack adapters you need, mainly for the fuel. I will buy about 100 of these things before a get the right ones,, PITA.
This post might help clear up some of your fuel fitting questions and concerns. It's really not that bad, especially with the kits specifically designed for the HSR.
https://www.thirdgen.org/techbb2/sho...hreadid=163946
HTH
I have a 383w/ 6"rods comp cams nitrous HP 268 cam, 210cc afr heads, headers blah blah.
since my combo is setup for most of its power above 3000, the stealth ram would be my best choice for EFI wouldn't it?
I mean a stock tpi would drop off only 1000 rpm after I started making power right?
opinions?
also, when siamesing runners, would the most benefit come from siemesing the intake manifold so each cylinder could use the volume of 2 runners?
could a stock tpi ever be modified enough to support an engine such as mine?
opinions?
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
