Pro Topline heads
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 87 Formula
Engine: 327
The factory is locked down and up for sale I guess. Something bout $17 million in debt. I've seen several threads/links and dealers talking about it. Rumor today is that Holley is looking into buying them, but someone working in the holley head dept hadnt heard anything about it. Lots of rumors, but no heads.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Re: Pro Topline heads
Originally posted by STIFFLER
Hey guys should I go with the 180 or 200cc pro topline heads for my XR270HR cam and miniram...
what do you guy think?
However, if they are having some issues I wouldn't touch anything of theirs until you see whats going on.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
If you can get them run the 200cc. The 180cc have been bench flowed to not flow nearly as high a numbers as pro claims below .6 lift.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I read a post elsewhere that they may be on a sinking ship. I'd wait and see whats going on, personally.
Hi there,
My name is Greg Stokes and I represent Pro Topline Limited in the Sales/Marketing and Technical dept. I can tell you right now that the government have not, has not and will not close us down. Our relationship with Topline is still as good as ever and we are still as busy as ever. We have had a fantastic year and are looking forward to the SEMA and PRI Shows where we both have booths at and have done for a number of years. This year we drove a street roadster to Bonneville with SO-CAL Speed Shop and run 194mph with a blown 355 Chevy running 200cc cast iron Lightnings. We also had another successful season in the World of Outlaws with Donny Schatz and Rip Williams. Our 14 degree cast iron heads are now running 7.0 second ets in the ever competitive Jr Fuel class campaigned by Wayne Ramay, Dean Carter and Kelly Craig. The list of achievements and successes is very long and we are also having a bunch of fun doing it.
We pride ourselves on the most powerful cylinder heads in the world for small block Chevy, big block Chevy, small block Ford and now Honda V-Tec. Heck we even have a number of engines qualified in the Top Ten that run our heads in the Popular Hot Rodding Engine Masters Challenge.
We have the most diverse mix of cast iron and aluminum racing and stock replacement cylinder heads and I invite you all to visit www.protopline.com or email me at greg@protopline.com
Many thanks and kind regards,
Greg Stokes
Sales/Technical/Marketing
Pro Topline Limited
Ph 1-866-776-4323
Greg Stokes
Pro Topline Limited
Ph 1-866-776-4323
Car: '87 Camaro LT
Engine: 355 L98
I got the angled plug heads and have no problems with plugs with my hooker headers. What I did was take a spark plug socket and cut about a half inch off the end. Then I use an 11/16" wrench to turn the socket, I can get to every plug this way and it only takes about ten minutes.
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
