Anyone with an EGR solenoid pic/diagram??
1 Post
Car: 89 Firebird Formula T-Top
Engine: SP383 FIRST Fuel Injection
Transmission: T56 Tremec Magnum
Axle/Gears: Moser 12 Bolt, 3.42 Eaton Posi
This is actually for my 89 Vette, but I think it might be the same setup as an early 90's l98 fbody. I hope so, cause the Vette forum isn't nearly as helpful.
I've got some busted plastic vacum lines, and theres nothing going to the backside with the metal clips. Thanks for any help!
There's not supposed to be anything going to the backside with the metal clips. That's just a vent, and I want to believe the metal clip is to keep anything from resting up against it and blocking it.
1 Post
OK, cool, I figured I was missing a piece all together for the backside. I think once I get the factory vacuum lines it shoud make sense where they go. I look on the fan shroud when I get home. Thanks guys!
HoosierinWA
10-07-2015 10:15 AM
