Pottential of the 305 tpi
Old 01-28-2003 | 07:37 PM
E.T.'s Avatar
How much power can be made with these engines. I want to be able to hit mid to low12's. I plan on doing a complete rebuild. So what can the 305's do.
Old 01-28-2003 | 09:42 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Mid to low 12s are perfectly possible. There are a few people here doing that. Willie on the power adder board runs a 12 flat at about 116mph.
It all comes down to how much you are willing to spend.
Old 01-29-2003 | 12:00 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the 305 tpi is like any other engine...yea it has a smaller bore then a 350 but can still make good power
the key to buidling a 305 is buying parts that are a little "overkill" so that when u build your 350 these parts will be perfect..
theres a guy here name tim burgess...hes got a 305 tpi with a tpis big mouth base large tube runners stock ported heads and a tpis l98 super profile cam and hes crankin 410 hp....transer those same parts to a 350 and you gonna be makein some real good power...
Old 01-29-2003 | 07:37 AM
E.T.'s Avatar
money is not a problem. So what mods would you guys recomend to get to make good power. Oh Yeah, where can i get a nice set of forged pistons for a 305. I can't seem to find them.
Thanks.
Old 01-30-2003 | 10:23 AM
bigals87z28's Avatar
Car: Check The Sig
i dont know if they make them for teh 305, but try PAW... let me know if u find them
Old 01-30-2003 | 11:57 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
TRW/Speedpro makes forged pistons.
The new TRW forged comes with much tighter recommended side clearance and teflon coated skirts
Out of the box the TRW's need a little deburring & polishing to smooth the edges, but they work and they are much better than they used to be. 305 pistons run around $400 & actually cost more than 350 pistons.
Old 01-30-2003 | 01:35 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Curious why you want to stick with the 305 when a 350 would probably cost you less in the long run and parts are plentiful.
Old 01-30-2003 | 02:57 PM
E.T.'s Avatar
I really just want to see what can be done with them, but i will probably go with a 350.
Old 01-30-2003 | 03:08 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
You sound like me, just have it stuck in your head and can't get it out. I have the same thing going on for a t-5 swap into my vette, better trannys out there but I want to make it work. I am even trying to install it at the angle it is in the f-body.
No matter what, good luck!
Old 01-30-2003 | 03:36 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
:rockon: :rockon: Finally someone understands !!!!!!!!
....but when I finally step up ...... it ain't gonna be no piddley'lil 350 ..... here's what I got in mind for starters
My dream starting point
Old 01-30-2003 | 03:47 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Now your talking!
I am going to put a 383 in my vette next year if the tranny survives behind a 350 for this summer. Then transplant my LT1 intake from the Formula into the vette and put a Holley Stealth Ram with a supercharger in the Formula. Should be fun!
Orr89RocZ
04-25-2016 08:28 AM
gta90
09-15-2015 04:00 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Pottential of the 305 tpi
