Fuel pressure regulator shimming??
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
What's this I hear about shimming the fuel pressure regulator with a quarter to get the pressure up by 4 or 5 pounds? Huh?
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You're better off buying an adjustable one. Every steup is different. It would suck to spend all that time removing everything (and wasting gaskets) and putting it all back together after finding out you should have used a nickel instead of a dime LOL.
Do you ever come down to Sac? I have tomorrow off. I can help you with your airbox if you want. In fact I might have a modified stock one already sitting in my garage somewhere (not sure though). Either way there are easy to modify.
Yo Danny,
I work in Rocklin, I have an 8 to 5 job, Mon-Fri.
Let's communicate on how best to get this resolved.
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
9192camaro
16
02-03-2019 12:21 AM
