GMPP runners?
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
GMPP runners?
Well, I picked up some siamesed runners off eBay, and they are labelled as GMPP. At the risk of sounding too newbie-
Are these the same as SLP runners? They look very similar.
Also, I never realized that one set of runners on each side is siamesed all the way down, while the other is only connected by about 3" of depth at the top... On the surface I would think this would be a power balance (or lack thereof) issue, but it's been a while since I've worked with a GM smallblock.
Are these runners decent?
Also, I got the 85-88 runners, so I believe I need the cold start injector blockoff to use them on my 90 Formula. Where would I be able to get the kit?
Thanks for any info!!!
Matthew A. Green --- mattgreen(at)msquaredracing(dot)com
M"squared" Racing! --- http://www.msquaredracing.com/
85 Shelby Charger- 260hp, no waiting!
87 GLHS #314
90 Formula 350- I think I'll have a V8!
98 P-Neon SOHC- ACR wanna-be
01 Ram Off-road- Something has to tow all this stuff!
87 GLHS #314
Car: 84 Z28
GM Part # 12341415
Are these things really that rare?
87 GLHS #314
87 GLHS #314
Car: 84 Z28
Here's a pic of them...
Any thoughts?
{hmmm, I thought I posted a pic}
Any thoughts?
Car: 84 Z28
Trying the pic again....
Or go to
http://www.msquaredracing.com/glhs31...d/gmppruns.jpg
if it doesn't show up...
Or go to
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Re: GMPP runners?
That seems kind of weird that one side on each runner is siamesed all the way and the other is not. Did SLP actually make those that way? You would think the air flow would definitely be unbalanced somehow between cylinders!
Car: 1990 Iroc-Z
Did the SLP package deliver the goods for the extra money back then? I was still playing with little plastic soldiers and riding my bike back then...
So does anyone remember if it made quite a difference? I can't imagine the prom to be to much better than some off the shelf junk.
Car: 87 Buick GN
If you can find the Aug 88 issue of 'Hot Rod' magazine, they did a test on an L98 IROC using the whole SLP package. I'm going completely off memory, but they knocked off almost a second in the quarter mile and the motor breathed better over the 4800 RPM "wall". I believe it ran like a 14.0x in the end. Back then that was pretty good, considering SLP's goal was to reduce quarter mile times by a second, stay 50 state emissions legal, and not reduce fuel economy.
RedLeader289
05-28-2019 01:47 PM
Royal_Z
09-30-2015 08:45 PM
