How difficult is it to repair helicoil in am edelbrock head?
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i recently purchased aset of 6085 edelbrock heads with only 3k miles on them. there r in great shape. the only thing that concerns me is a thread on the driver's side head ,were the power steering and alternator bolt up. iwas crossthreaded and the helicoil in the hole is shot. how would it be removed? and a new one inserted? bye the way should i notice a big gain over my current combo? i am also adding the edelbrock base?
thanks
thanks
Guest
Posts: n/a
Those can be kind of a PITA to fix sometimes. Its already helicoiled now? If the helicoil itself is actually damaged (I'd be surprised), you basically have to unwind it from the hole. Sometimes you can grab the end and just pull it out, but many times it'll get jammed in there doing it like that. Installation after getting the old one out is simple, as long as you have the insert and the tool... or something just like the tool.
theshackle
03-05-2017 06:37 PM
86IROC112
08-17-2015 02:00 PM
edelbrock, elderbrock, elebroke, fe, head, header, heads, helicoil, helicoiled, helicoilin, lt1, removal, removed, repair, repairing
