Anyone running the LT4 hotcam and HSR???
1 Post
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Just curious who is possibly running a hotcam with the HSR?? Can't decide whether I want to run the LSR or a modified LT1 intake. They're about the same cost overall, but the HSR can be purchased new and completed minus any troubles the LT1 intake might cause me. Any thoughts opinions on this? Think the hotcam and HSR would be a good combo?? TIA!
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Unfortunately Im not running a HSR with my hotcam yet. Even though the LT1 is a proven performer in LT1s, it is too much of a chop job with the cooling for me.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Mike (85MikeTPI) is running the HSR and an LT4 Hot Cam with AFR190s and is running 11.8s@114+ MPH. Full weight too!
Kevin (kevinc) is also running the HSR and LT4 HOT Cam with AFR190s. No times yet but from what I know he is really happy with it.
Tim
Tim
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Tim
Tim
and the siamesed TPI base:
http://www.eecis.udel.edu/~davis/z28...age021105.html
Depending on how well your iron heads are ported,
you may need to move to some better ones to reap
the HSR benefits..
mike
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Hey Mike,
All you need now to become the offical database for intake/hot cam comparo's is a dyno sheet of a SuperRam mated to your engine. That would help a lot of people out on this board, including me, in terms of ideas for what to do. Kick *** numbers by the way.
1 Post
Car: 89 formula
Engine: 383
I have the HSR and HOT cam no times or dyno #s yet(just put the engine in).I have yet to tune my combo yet but I think the hot cam is but mild for me.The comp XR282HR looks lot more promising with the stealth ram.
1 Post
Car: '91 GTA
Engine: 402ci LS2
Thanks guys! I think I might just go with the HSR. I'm still gonna save for AFR 195's though. Guess I'll see how it does with the hotcam and iron heads first. Thanks again!
Mike, great dynoe numbers, looks like a more well balanced engine now and not such a torque monster. LOL That thing looks like it just keeps pulling and pulling and pulling! What kind of ET/MPH gains did you get by swapping to the HSR?? I see the improved dyno numbers, but what about ET/MPH??? Thanks! Later
Originally posted by camarojoe
Hey Mike,
Hey Mike,
on though... 8-) [PITA-ram]
Seriously though, I may get to it next year if
the one down the street is off by then... 8-)
I have a single-plane EFI also, but it wasn't
as good as the HSR.. (12.1 @ 111) I was
at the dyno with it, but the dyno broke before
I could get on..
mike
bottom..
Over the siamesed-TPI it gained about 4
tenths and 5mph.
(over the EFI single plane it gained about 3
tenths and 3mph.)
mike
assumeing you have at least a 4.11 rear gear and a 3500 stall converter or a manual trans heads that flow at least 250cfm@.500 lift and a good exhaust/headers and performance is the most important goal these two cams BETTER match the flow and rpm curves of the HSR than the hot cam
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
From the GMPP catalog:
24502586 Hydraulic Roller (LT4 Hot Cam)
This hydraulic roller cam is for service only for all V8 engines with
roller camshafts. The duration at lash point in degrees
(intake/exhaust) is 279/287; duration at .050" tappet lift
(intake/exhaust) is 218/228; and maximum lift with 1.6 rocker ratio
(intake/exhaust) is 525/525. Valve lash is zero/zero and lobe
centerline is 112 degrees.
try it in your DD-2000 software or your engine and youll see what I mean, Im running the #119661 in my 383 and have run the http://dab7.cranecams.com/SpecCard/D...1=Display+Card
which is cranes version of the hot cam for a short time. (which is a great hot street cam BTW but not a true PERFORMANCE/RACE cam
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Nice #'s mike. What kind of suspension stuff are you running to pull that kind of 60'?
I'm running the CC306 in my car w/ the stock TPI. I noticed a difference in how the car acted right away. I'll be going w/ the HSR in the near future. I'm hoping for a mid-low 12. And then spray an 11. Am I way off here, or is it very possible w/ minor tuning? :hail: :hail:
1988iroc350tpi
08-14-2015 07:52 PM
