aluminum plenum extension cover, GM part #?
1 Post
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I don't know the GM part #, but I got mine at www.corvettecentral.com . It is only $21.95 and $2.50 for the 3 screws needed.The dealers in my area wanted around $40 to $50 for the extention and $5 a piece for the screws.
1 Post
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
10108425
Plenum Cover - Alum. - Corvette - To replace plastic one when polishing plenum.
I got mine through P & G Chevy for under $15 I thought although right now its a little more than that
https://www.partszoneonline.com/index.html
Also check
http://www.gmpartsdirect.com
Also check
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
GM P/N 10108425 Aluminum Plenum Extension
GM P/N 14082425 Screws (for plenum extension) x 3
Thanks for the replies!
I wanted the part # to check out www.gmpartsdirect.com ....thanks for the screw part #'s too.
