roller tip rockers for ZZ-4 heads
Car: 87 L98 TPI
Engine: ZZ-4 heads, LT1 cam, AUJN Prom
I've got some D-port ZZ-4 heads( from a 90 vette ) going on an 87 L-98 and also will be adding a 94 Lt-1 cam out of a trans-am. can i go for a straight bolt on with some 1.6 roller tip rockers to this setup?? None of the online catalogs say whether the roller tips are self-aligning or not.
I'm guessing I need self-aligning but am not sure.
also can i use the stock 87 L-98 pushrods??
Do i need to remove the guideplates ??
Any advice would be appreciated.
Car: 87 L98 TPI
from my understanding the guideplates on the vette heads fromm 88 on were no longer hardened and only there to hold the pushrods in place for assembly. So the rockers were self-aligning from 88 on. Any comments on this??
I have '88 vette heads on my 305 and they had guide plates that are worthless. After about 100 miles one of the rocker arms slid off the center on the valve, bent the push rod and wore a big gouge in the guide plate. (no other damage ) You need to use self-aligning rocker arms with these heads.
Car: 87 L98 TPI
thanks for the input. Think i have it sorted now. found Comp cams self-aligning roller tips which will work for my setup.
I have a stock 350tpi l-98 with just intake/exhaust done. Do you have a part number or description of a roller tip rocker that would work on my motor with having to modify anything? Cheaper is better. I would like to run a larger ratio for a bit more duration instead of putting in a new cam. Thanks for the help.
I just picked up a set of these. I should get them on in a two weeks or so. I'll let you know how they work out.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1874114860
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Originally posted by madmax
Iron heads? Self aligning rockers? Need to know.
www.fl-thirdgen.org/rockerswap.html
Engine: 360 HSR
iron heads have no guideplates. and yes they are slotted. i've been doing this for a little while. so long as the holes are slotted, then non SA will work. if the holes are round then SA are required. the whole SA thing is such a farce. it's nothing more than redundancy because GM made such crappy rocker arms to begin with. yes, i have read the posts where people have switched from SA to non-SA rockers and had problems. something else is wrong. maybe rocker not adjusted properly. stud pulling out causing the rocker to come loose and fall off. i had the comp cams 1412-16 1.52 non-SA on since at least march 2002. until i put the 1.6 full roller rockers on in sep 2002. no problems. but i will always remember a man named murphy. it works for me, but someone else here will try it and have a problem.
Guest
Posts: n/a
Well I've been doing this for a while too, in case you were thinking otherwise. You need some sort of pushrod control, but having 2 invites room for problems. I have personally witnessed the damage on other peoples cars. And I know most stock iron heads didnt come with guideplates, doesnt mean there arent any on now.
I know GM did use some slotted heads with SA rockers. Their SA rockers have tons of side-side play though. The aftermarket SA rockers I have seen have much tighter tolerances. Doesnt leave much room for error.
Engine: 360 HSR
Well I've been doing this for a while too, in case you were thinking otherwise. You need some sort of pushrod control, but having 2 invites room for problems. I have personally witnessed the damage on other peoples cars. And I know most stock iron heads didnt come with guideplates, doesn't mean there arent any on now.
Guest
Posts: n/a
I'd just like to add... I hate GM SA rockers.
Ferd's design aint any better. I ditched those off my Ferd a long time ago.
Your 86 had SA rockers on it huh? Weird. Someone had to have swapped those on at a later date. I've seen worse though, amazing what sorts of stuff people do to engines.
Engine: 360 HSR
Originally posted by jmd
Then the rockers were not original.
Matthew
Matthew
Originally posted by mrr23
sorry to disappoint you. but it was the original 5.0l 153k on it when i got it. car was all original right down to the crappy red interior. but hey i could be wrong. i'll check the old rockers tomorrow at work.
153 raises suspicion to me. Not trying to be harsh.
Matthew
Engine: 360 HSR
ok found my original rockers. they are the non SA design. my mistake on that one. will have some pics up shortly.
Engine: 360 HSR
going to post some pics. not the best. the middle one is a SA arm. the outer ones are non-SA. as you can see, the non-SA one on the left moved alot side to side. the one on the right barely moved at all. has the same wear pattern as the SA rocker. so, either the pushrod was bending side to side causing the rocker to move. or the rocker flexed more than the other one. causing it to shift to one side and the other. or rocker loose due to lifter collapsed, stud pulling up or nut backing off. i would believe one of the 1st two.
Engine: 360 HSR
next. the one on the right didn't wear in the middle either. it was to one side. this would indicate that the pushrod hole in the head wasn't where it needed to be. due to core shift making the head.
Engine: 360 HSR
finally, they made the SA arms to force the rocker to stay centered on the valve because the the core shift in the making of the heads. this made the pushrod not completely parallel with the stud.
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
gixxer92
09-01-2015 04:32 PM
IrocZ'85
08-17-2015 06:24 PM
