Gear Drive effect on knock sensor
Car: 04 GTO
Transmission: M12 T56
Plenty of people have successfully run knock sensors on engines with gear drives. Notables include moderators Wille and Madmax, and i think Tim Burgess too for some reason.
Guest
Posts: n/a
Well like Ed said, I'm using one. No false knock problems. I am beginning to think the engine is filled with leprechauns(based on other bad things I shouldnt have done), but other people (like Willie) also are running the same gear drive without problems. Pete Jackson 'Quiet' drive.
I have to ask... what do you want to run a gear drive for?
350 .060 over flat top pistons etec 202 heads comp cam 268 .515 .520. al comp roller
i built this motor about 4 years ago except for the heads where a little older style, and i was very happy with the results. i just wanted to change it aup a little
edit: this is another motor i am building now...
CarGuyDennis
137
12-06-2016 11:02 PM
