1989 5.7 Camaro/Firebird SLP chip/Prom
1 Post
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
Selling a 1989 5.7 Camaro/Firebird SLP chip/Prom. This was purchased via SLP 5 months ago and the GTA was driven only on weekends. Like new! I am keeping the GTA stock and storing it for winter. Dont need this prom any longer and SLP no longer sells them. $69 plus $5.50 Priority Mail. Below is a from SLP.
"REGULARLY $135.95 NOW $69.95 Proms, 1989 Camaro/Firebird 5.7L auto dual catalyst, 50 state SLP’s prom’s are made by recalibrating brand new GM Cal-Pac’s, not by simply soldering a Prom onto a Cal-Pac. While this keeps cost down, you get a more reliable chip. The proms are recalibrated to optimize spark timing and air/fuel ratios for increases in wide open throttle performance, and turn your electric fan on at 200ºF (20º degrees cooler than stock). Note: All proms are sold as is, all sales final, no exceptions. Proms, 1989 Camaro/Firebird 5.7L auto, 49 state
SHIPPING CHARGE TO SHIP ONE OF VIA UPS GROUND $10.95
Car: 1990 Iroc-Z
Is it a crap chip like hypertech or something similar with very little changed that one couldn't do themselves with little time investment - or does SLP make a more "real" chip? Like, does it actually improve performance significantly, and is it aggressive enough to not have to change later once many mods have been done for power?
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Not worth it at all, do it yourself
On a side note:
When I looked at a Hypercrap chip my friend had they only changed the fan temp and like 5 numbers on the spark advance table, very lame. That’s about 1 minute of work.
Has anyone looked at the SLP prom? I assume they are just doing the exact same thing.
On a side note:
Car: 91 Camaro Z28
Engine: 5.7 TPI
My mechanic had one laying around so I put it in to see if it would help.......NOPE, NOTHING, ZERO, ZILCH. It is a waste of time if you ask me. Oh and I had a Hypertech chip too when I bought the car and when I took it out I ran the same times.
Car: 2004 GTO
Originally posted by slayer2000
in before the lock
in before the lock
MODERATORS: Can we get a sticky for posting of this stuff?
Back to the topic,
I had an SLP Stage II chip, exact same one as above. Didn't really notice much with it. I took it out and lost it. I hear the SLP chip is one of the better ones out there.
If you guys are in the buying mood I've got an ADS superchip that my car had when I got it. 87 305 tpi
My brother had a hypertech chip and he said all it did was give him bad gas mileage. I haven't researched the ADS or SLP chips, but I know you can't edit the ADS(thanks previous owner, $65 for a stock chip when I got a new engine). Anyway, I ran 14.5 @ 96 with the ADS chip in my 305, but the engine itself was burning a quart of oil between gas stations. Would have been interesting to try a stock chip, had I known it wasn't stock back then.
Unfortunately, in order to keep it smog legal, all they do is mess around with the WOT a little bit. They also cannot severely alter the operating temperature of the engine since that greatly affects emissions.
I've looked at a Hypertech chip and it's nothing. It's somewhat incredible considering the price they charge for a $2.50 PROM that they burn at probably 10 or more at a time.
no green
01-09-2016 09:22 PM
KO1
16
10-15-2015 05:00 PM
LT1Formula
10-08-2015 08:34 PM
Royal_Z
09-30-2015 08:45 PM
