PRICE of stock GM TPI 88ŽInjectors????
A fast one:
how much are stock GM tpi injectors for a 88 gta??
No aftermarket pls! The ave GM Dealer price and part number wanted!
The P/N for A/C Delco 22# Fuel Injectors is 17111961 and expect
to pay Between $80/115 each for these. They are not CHEAP.
I paid over $700 for a set of (8) two years ago. Check out gmpartsdirect.com for starters.
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
Are the Accel injectors reliable?? I have to replace my injectors soon, but need info.
Go for the Accel set,
I know two different cars running them for years now with no problems and they receive their healthy dose of drag strip runs every season.
Why are you insisting on using GM's stock injectors? The aftermarket ones from Accel are just as good if not more efficient than stockers. Why spend over $700 when you can get them for $240? Silly German Guy
Thanks for all your answers!
We have a member that "needs" his stock gm parts...hahhaha!
Strange guy but cool somehow!
I checked some data and got up with diff numbers so i pulled into third gen!
I got a set off 36 offered for 300 $ new......i feel that there is a large jump on prices the higher you go!Mhmm?
Well silly is the wrong term my friend, to each his own!
The 88 GTA Notchback he owns would make you blind...lol!
Can someone supply bosch numbers , that would be a challange for our parts trader! A bonus for us , cause we have a 40% off!
Multec owners in here??
Guest
Posts: n/a
Great explaination, but his original question was " ORIGINAL STOCK TPI INJECTORS FOR A 88GTA" . And my reply was " A/C Delco P/n 17111961 which you use to order the orginal GM part.
You are correct that the number on the injector is 5235302. Why confuse the issue when he just wanted the original injector part number. So german-motorsport that is the number you asked for
without the confusion.
Car: 88 GTA Notchback WS6
Engine: 350 with a SuperRam
Sorry.... the intent was not to confuse anyone. I thought it would be a good opportunity to straighten out some mis-information about the various injectors since other injectors such as MSD's, Accels, SVO's, ADS's, and Bosch's had been mentioned in this thread. I was going to explain the similarities and differences between those also, but I won't so that it doesn't add to the confusion.
Car: 86 IROC-Z
Engine: 406
i have some 24 and 26 lb injecotrs for sale. the 24s were on my car for about a year.. the 26s are the 1's i have in now, but only have 2000 miles on them. im getting 30 lb injecotrs here soon.. i can sell u either set for $150 if u want.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
They are rated at different levels. SVO are rated at 39.5 psi, stock injectors or Bosch are rated at 43.5 psi. That changes alot of things when you say 24# injectors. Those same size injectors from two companies at different psi would be off. Do a search for calculations before you buy anything but stock.
Sanjay
08-12-2015 03:41 PM
