Adjustable regulator fuel rail for stealth ram
Car: 1989 IROC
Does the fuel rail with the adjustable regulator hook up to the fuel lines just like the non adjustable regulator fuel rail?
I need to know what I need to run the fuel lines from stock to the stealth ram. Just want to make sure it is the same because I think the stick refers to the non regulated with the fittings that are required
thanks
Tim
thanks
Tim
Car: 87 IROC-Z
Engine: 383 HSR $8D
I bought the fuel rail kit for my HSR with the adjustable regulator...and have looked at standard GN regulators...the fuel fittings will be the same, either way. I plumbed into the inlet with a straight fitting and the regulator with a 135^ fitting(just cuz that's what I had)...
9192camaro
16
02-03-2019 12:21 AM
L98GTA87
08-11-2015 06:55 PM
