edelbrock tpi baseplate/runners
Car: 1988 IROC-Z
Engine: LB9
will the edlebrock tpi baseplate and runners work good with a 305 if i had either stock heads or somethin like world products 305 torquers, with edelbrock TES headers and a new cam and throttle body....does this sound like a good setup? tell me what u think, thanks a lot
Car: 1988 IROC-Z
Engine: LB9
oh...and the edelbrock runners say on hegs that they are 89 and over engines...why is this...i have an 88...will they still work?
reason they say 89 and over is cause there runnners arent for Cold Start injection. I believe its from 85-88' U should call jegs and Summit im sure they have Edelbrocks Runners for 85-89. As for the setup, All i have is their intake and TES headers and i like em.
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
The TPI is designed for a 305 and pretty much flows well enough for it, possibly even if the heads were upgraded. That is not to say that on a 305 it won't start power loss at 4500rpm, becuase it will.
However, if you go upgrading the TPI components on a stock 305 you may bog it down with air and kill all kinds of torque especially in the lower R's. Honestly, some people with stock 350's see next to no gains... Having all of this said, I would spend the money elsewhere on a 305.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Originally posted by IROCZ88x
oh...and the edelbrock runners say on jegs that they are 89 and over engines...why is this...i have an 88...will they still work?
3890 for both the runners and intake
3860 just the baseplate
3865 just the runners
theshackle
09-17-2020 08:26 AM
BlackphantomZ28
08-22-2015 01:00 PM
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
