Stock valve cover hole diameter
1 Post
Does anyone happen to know the diameter of the hole on the passenger side valve cover (not the side with the PCV and oil fill).
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Just measured mine with a digital caliper and got .950
Depends on what drills you have access to, but you can use 24mm @ .9449, or US 61/64 @ .9531
Hope this helps.
Dan
Hope this helps.
Dan
NBrehm
08-25-2015 11:49 PM
Street Lethal
08-12-2015 11:33 AM
