SLP Cold Air - Remove the Canister?
Car: 1987 Pontiac Trans Am GTA
Transmission: WorldClass T5
Axle/Gears: 3.70
I just bought a used SLP Cold Air Single Inlet system for my 87 GTA. I have a question. Does anyone know what to do with the fuel canister?
The SLP filter box takes up the entire area that used to have the stock filter box and the canister sitting next to it...
Anyone have any pics of one installed?
Thanks in advance!!
Thanks in advance!!
Car: '89 TA
Engine: LB9
Transmission: M5
Borg:
I don't have access to pics now.. but I moved my canister about 1 foot directly below where it sits stock, on a brace that is diagnonal from the lower area of the passenger fender to one corner of the radiator area. All the tubes and connectors didn't need to be added to, just simply re-routed below. Hope that helps a bit. If you have follow-up questions I'll be happy to try and field a few
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Does this SLP kit work
for an IROC 350 with a TPI on board ? I just broke my air snorkel and I really don't want to spend 50 bux on that cheap *** piece of plastic if I can get a better replacement. (SLP CAI kit)
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I just installed mine and initally put in next to the battery, but that was a bad spot so I just got rid of it.
Car: 1989 Trans Am
Transmission: 700R-4
they should have sent you some relocation vacumn and wire lines with the kit. i put mine just in front on my battery and used industrial zip ties to hold it down. wrapped them around the wiring harness that runs on the frame rail. then ran the new vacumn lines under the throttle body with the rest of the wires under there. hope this helps
FUEL CANNISTER RELOCATION
I put my canister underneath in the nose section. There is a brace there and just used a large hose clamp.(actually 2). I had to lengthen the wiring and got new longer hoses but the cost was cheap. You can see the area if you look thru the hole where the hood connects in the down position.
88 FORMULA 350
88 FORMULA 350
Car: 1987 IROC Z
Which kit would I need, anyone know ?... ( I have already relocated my battery to the rear) They have a couple listed on SLP's site, unsure which I would need.
Axle/Gears: 3.70
Depends on the year of your car. Either go online to SLP and look it up (http://www.slponline.com/powersearch.asp) or give them a call...
Car: Formula
Transmission: M5
I just bracketed mine to the driver side near the strut tower. I had to make longer hoses and loom the wires. There's too much junk in the way to put it where SLP says to.
Ghettobird52
07-05-2024 11:18 PM
Brinkkl2000
08-04-2018 08:29 AM
db057
08-11-2015 10:11 PM
