LPE 219 Cam?
LPE 219 Cam?
I'm planning to get SuperRam on my 5.7 TPI. I hear LPE 219 Cam works best with it, is that right? Also, throw in some suggestions for Cyl Heads I should look into.
Ya that cam is perfect for the super ram! The heads depend on how much money you have to spend. Whatever you do dont get heads that are to big. They will kill your torque and thats the strong piont of a TPI.
Thanks. The biggest thing I'm hearing about now are the AFR 190 heads. But I guess they're a little expensive too. I was thinking of the TrickFlow 23° Heads or the Edlebrock Performers. I actually hear those Edlebrocks are good. But there's also an 88 GTA running low 12's with those TrickFlows. But he's also got an Intrcooled Procharger. But he said the heads are doing well. I'm still unsure. I also heard the L98 D-Ports from TPIS are good, but not worth the money. Anyways, let me know. Thanks.
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Absolutely get the LPE 219 w/ the SR! And get the AFR's if you possibly can, they are great heads. If not, the Trickflows should be ok. Check out my sig. below.
