cam choice questions. LT4 Hot Cam??
Old 10-09-2002 | 06:26 PM
Nasty_Bird_'90's Avatar
L98 is coming along now, and I still need a cam. Thinking about the LT4 hot cam kit, but from what I've seen, i need the spring seats machined out and have a new memcal chip burned so the computer will act right. This is a budget buildup and don't have the $$$ for a bunch of headwork. How much is actually involved? Is there an alternative to the LT4 cam that will perfom comparably and not require all the machining? I've seen the ZZ9 being tossed around quite a bit. I plan on a head rebuild and new springs anyway, but the Hot Cam kit is too expensive in itself. And then add the machining costs to that and it's over 1000 bucks. Any help is appreciated. Thanx
Old 10-12-2002 | 04:08 PM
ttt
Old 10-12-2002 | 09:20 PM
u r sofa king we tah did's Avatar
the hot cam kit is a good price for what you get. getting the spring pockets opened up and the valve guides shaved to handle .525 lift wont cost that much.
Old 10-14-2002 | 02:03 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
What kind of intake?
If carb - should be ok depending on heads.
If TPI - it's a bit of a mis-match since TPI peaks before the LT4 HOT really starts making power.
If LT1/StealthRam - much better than TPI combo.
HTH...
MustangBeater20
10-29-2022 09:20 PM
camaro71633
09-01-2015 10:24 AM
80s Poncho
08-19-2015 06:45 PM
1988iroc350tpi
08-14-2015 07:52 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: cam choice questions. LT4 Hot Cam??
