Breather, Oil Cap, PCV, Valve Cover Question!!!!
Ok, with the LT1 intake, the PCV is in the side of the intake.
Soooooo..
My one valve cover has two openings, the other has one.
1)Can I put the oil cap on and a breather in each of the other holes
2) Put oil cap on one, some kind of cap (oil cap?) on another, and breather on the last.
3) or put some kind of cap on all 3
Soooooo..
Put th PCV in one of the driver side holes, Put breathers in the other two if it makes you feel Good.
As long as you have some circular flow through the crankcase, your in good Shape.
1992 Trans Am
05-10-2023 07:19 PM
