need help my timing is off bye 30 degrees?
Car: 98 Camaro Z28
i put a Recon 88 L98 in my 87 gta, and i cant seem to get the timing to be at 6 degrees its off like 30 degrees but the car runs ok what would cause that? anyone have a clue that would help me? i think the car might have a 305 ESCM if that would make a difference and the engine has a 350 knock sensor.
Car: 04 GTO
Transmission: M12 T56
Initial timing is a completely mechanical setting. It has nothing to do with the computer or the engine. It has to do with where you put the dizzy in. Keep moving the distributor until you have the timing in the right place, it's that simple.
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
your balancer could be messed up. On my stock balancer the outer ring came loose from the inner one causing the timing mark to be way off.
Hodge
Hodge
theshackle
09-17-2020 08:26 AM
